Parametric Audio Equalizer
Pontus Rydin has created an audio equalizer and general purpose “DSP playground” using the Teensy 4.1 for digital signal processing.
A custom PCB based around the ESS ES9039Q2M 32-bit high-performance two-channel DAC provides digital-to-analog conversion, and a CYD (Cheap Yellow Display) with dedicated ESP32 graphics processing via I2C furnishes the UI.
While the device currently functions as a preamp and eq, Pontus says that “thanks to the awesome power and versatility of the Teensy, I can make it do pretty much any audio processing. I will add a graphic equalizer in the near future. I might add things like reverb and wide stereo if I get bored.” The 32-bit, 192kHz audio pipeline is custom, based on the Teensy Audio Library, using single-precision floats to simplify the math. Code and KiCad files can be found on GitHub.
