The TGA Pro is stereo-sound capable and designed specifically for use with guitars providing an onboard preamp specifically designed for the wide range of voltages and impedances encountered when dealing with guitars, pedals and guitar amps. It also provides onboard MIDI connectors for use with the Arduino MIDI library, and optional external SRAM for additional data storage. This shield makes it very easy for musicians to add effects while playing guitar.
In this video demo the only gear used is a guitar, the TGA, a MIDI expression pedal, and a tube amp. The expression pedal is used to open the input to the SOS channel and feed in the same chord in two different octaves to get a nice blended background ambience.
Over 20 of the pins are broken out by this board. It also sends power and ground to many of the connectors, making it useful for wiring in sensors and peripherals.
Forum user luni couldn’t find a stepper motor library to meet his needs, so he wrote his own. The library is able to handle up to 300,000 steps per second.
This video shows two steppers running up to 160,000 steps/sec.
There is a great write up and explanation on luni’s GetHub Page. The page includes excellent explanations and diagrams on the three types of movements.
The library handles the three different movement modes when controlling more than one motor – Sequential Movement, Synchronous Movement, and Independent Movement.
Luni published performance metrics running 1 and 3 motors on 2 different boards.
This neat little gadget can do things like generate PWM or DAC signals, read serial output of your microcontroller project, as well as several other useful functions. The design of the Little Helper was inspired by the iPod interface. It’s custom touch wheel allows for fast one-handed operation.
The project is open source. You can find the code on Github.
The folks over at Cirque have put together a kit for trackpad development. This nifty little kit is Arduino based and includes everything you need to get going with trackpad development.
vitormhenrique recently posted about his custom arcade machine over on the forum. This is a great looking cabinet and it even lights up with LEDs when not in use.
The forum post offers some more details about the build. vitormhenrique has made the controller board public on OSH Park and is planning to make the plans and code available as well.
