Long-time PJRC forum contributor ghostintranslation is back with a new version of the Drone Eurorack module, dubbed Drone 2.0 for its basis on the updated Motherboard 2.0 platform.
The module features four voices with sine and resonant noise oscillators, FM control voltage (CV), individual volts per octave, and a TRS MIDI.
The Motherboard platform underpinning all this was designed to facilitate the creation of new modules, without having to start from scratch every time, and itself features 16 inputs and outputs, MIDI in/out, 10-pin Eurorack power, and Teensy 4.0-based firmware and examples.
Drone 2.0 is available as a PCB/panel kit with SMD components prepopulated. The required BOM, as well as firmware and schematics, can be found in the project’s GitHub repo. Listen to example sounds below!
