(normative)
The I/O connector is a 40-pin connector as shown in figure A.1, with pin assignments as shown in table A.1. The connector shall be keyed to prevent the possibility of installing it upside down. A key is provided by the removal of pin 20. The corresponding pin on the cable connector shall be plugged.
The pin locations are governed by the cable plug, not the receptacle. The way in which the receptacle is mounted on the printed circuit board affects the pin positions, and pin 1 shall remain in the same relative position. This means the pin numbers of the receptacle may not reflect the conductor number of the plug. The header receptacle is not polarized, and all the signals are relative to pin 20, which is keyed.
By using the plug positions as primary, a straight cable can connect devices. As shown in figure A.1, conductor 1 on pin 1 of the plug shall be in the same relative position no matter what the receptacle numbering looks like. If receptacle numbering was followed, the cable would have to twist 180 degrees between a device with top-mounted receptacles, and a device with bottom-mounted receptacles.
1 |
40 |
20 |
2 |
Circuit board |
Circuit board |
1 |
40 |
20 |
2 |
Figure A.1 - 40-pin connector mounting
Signal name |
Connector contact |
Conductor |
Connector contact |
Signal name |
RESET- |
1 |
1 |
2 |
2 |
Ground |
DD7 |
3 |
3 |
4 |
4 |
DD8 |
DD6 |
5 |
5 |
6 |
6 |
DD9 |
DD5 |
7 |
7 |
8 |
8 |
DD10 |
DD4 |
9 |
9 |
10 |
10 |
DD11 |
DD3 |
11 |
11 |
12 |
12 |
DD12 |
DD2 |
13 |
13 |
14 |
14 |
DD13 |
DD1 |
15 |
15 |
16 |
16 |
DD14 |
DD0 |
17 |
17 |
18 |
18 |
DD15 |
Ground |
19 |
19 |
20 |
20 |
(keypin) |
DMARQ |
21 |
21 |
22 |
22 |
Ground |
DIOW- |
23 |
23 |
24 |
24 |
Ground |
DIOR- |
25 |
25 |
26 |
26 |
Ground |
IORDY |
27 |
27 |
28 |
28 |
CSEL |
DMACK- |
29 |
29 |
30 |
30 |
Ground |
INTRQ |
31 |
31 |
32 |
32 |
reserved |
DA1 |
33 |
33 |
34 |
34 |
PDIAG- |
DA0 |
35 |
35 |
36 |
36 |
DA2 |
CS0- |
37 |
37 |
38 |
38 |
CS1- |
DASP- |
39 |
39 |
40 |
40 |
Ground |
Recommended part numbers for the mating connector and cable are shown below, but equivalent parts may be used.
Connector (40 pin) |
3M 3417-7000 or equivalent |
Strain relief |
3M 3448-2040 or equivalent |
Flat cable (stranded 28 AWG) |
3M 3365-40 or equivalent |
3M 3517-40 (shielded) or equivalent |
When the device uses the 40-pin connector, the device receives DC power through a 4-pin connector. The pin assignments are shown in table A.2. Recommended part numbers for the mating connector to 18 AWG cable are shown below, but compatible parts may be used.
Connector (4 pin) |
AMP 1-480424-0 or compatible |
Contacts (loose piece) |
AMP 60619-4 or compatible |
Contacts (strip) |
AMP 61117-4 or compatible |
Signals Connector Plug |
DuPont 86451 or equivalent |
Signals Connector Receptacle |
DuPont 86455 or equivalent |
The signals assigned for 44-pin applications are described in table A.3. Although there are 50 pins in the plug, a 44-pin mating receptacle may be used(the removal of pins E and F provides room for the wall of the receptacle).
Some devices may utilize pins A, B, C and D for option selection via physical jumpers. Such implementations may require use of the 44-pin receptacle.
The first four pins of the connector plug located on the device shall not to be connected to the host, as they are reserved for manufacturer's use. Pins E, F and 20 are keys, and are removed. See figure A.3.
Signal name |
Connector contact |
Conductor |
Connector contact |
Signal name |
Vendor specific |
A |
B |
Vendor specific |
Vendor specific |
C |
D |
Vendor specific |
(keypin) |
E |
F |
(keypin) |
RESET- |
1 |
1 |
2 |
2 |
Ground |
DD7 |
3 |
3 |
4 |
4 |
DD8 |
DD6 |
5 |
5 |
6 |
6 |
DD9 |
DD5 |
7 |
7 |
8 |
8 |
DD10 |
DD4 |
9 |
9 |
10 |
10 |
DD11 |
DD3 |
11 |
11 |
12 |
12 |
DD12 |
DD2 |
13 |
13 |
14 |
14 |
DD13 |
DD1 |
15 |
15 |
16 |
16 |
DD14 |
DD0 |
17 |
17 |
18 |
18 |
DD15 |
Ground |
19 |
19 |
20 |
20 |
(keypin) |
DMARQ |
21 |
21 |
22 |
22 |
Ground |
DIOW- |
23 |
23 |
24 |
24 |
Ground |
DIOR- |
25 |
25 |
26 |
26 |
Ground |
IORDY |
27 |
27 |
28 |
28 |
CSEL |
DMACK- |
29 |
29 |
30 |
30 |
Ground |
INTRQ |
31 |
31 |
32 |
32 |
reserved |
DA1 |
33 |
33 |
34 |
34 |
PDIAG- |
DA0 |
35 |
35 |
36 |
36 |
DA2 |
CS0- |
37 |
37 |
38 |
38 |
CS1- |
DASP- |
39 |
39 |
40 |
40 |
Ground |
+5v (logic) (see note1) |
41 |
41 |
42 |
42 |
+5v (Motor) (see note 1) |
Ground(Return) (see note1) |
43 |
43 |
44 |
44 |
TYPE- (0=ATA) (see note 1) |
Note : 1 Pins which are additional to those of the 40-pin cable. |
This subclause defines the pinouts used for the 68-pin alternative connector for the AT Attachment Interface. This connector is the same as the one defined by PCMCIA. This subclause defines a pinout alternative that allows a device to function as an AT Attachment Interface compliant device, while also allowing the device to be compliant with PC Card ATA mode defined by PCMCIA. The signal protocol allows the device to identify the host interface as being 68-pin ATA or PC Card ATA.
To simplify the implementation of dual-interface devices, the 68-pin AT Attachment Interface maintains commonality with as many PC Card ATA signals as possible, while supporting full command and signal compliance with the ATA standard.
The 68-pin ATA pinout shall not cause damage or loss of data if a PCMCIA card is accidentally plugged into a host slot supporting this interface. The inversion of the reset signal between the ATA and PCMCIA interfaces prevents loss of data if the device is unable to reconfigure itself to the appropriate host interface.
This Specification relies upon the electrical and mechanical characteristics of PCMCIA and unless otherwise noted, all signals and registers with the same names as PCMCIA signals and registers have the same meaning as defined in PCMCIA.
The PC Card-ATA specification is used as a reference to identify the signal protocol used to identify the host interface protocol.
Any signals not defined below shall be as described in the ATA, PCMCIA, or the PC Card ATA documents.
Table A.4 shows the ATA signals and relationships such as direction, as well as providing the signal name of the PCMCIA equivalent.
Table A.4 - Signal assignments for 68-pin ATA
Pin |
Signal |
Hst |
Dir |
Dev |
PCMCIA |
Pin |
Signal |
Hst |
Dir |
Dev |
PCMCIA |
1 |
Ground |
x |
x |
Ground |
35 |
Ground |
x |
x |
Ground |
2 |
DD3 |
x |
x |
D3 |
36 |
CD1- |
x |
x |
CD1- |
3 |
DD4 |
x |
x |
D4 |
37 |
DD11 |
x |
x |
D11 |
4 |
DD5 |
x |
x |
D5 |
38 |
DD12 |
x |
x |
D12 |
5 |
DD6 |
x |
x |
D6 |
39 |
DD13 |
x |
x |
D13 |
6 |
DD7 |
x |
x |
D7 |
40 |
DD14 |
x |
x |
D14 |
7 |
CS0- |
x |
x |
CE1- |
41 |
DD15 |
x |
x |
D15 |
8 |
i |
A10 |
42 |
CS1- |
x |
x(1) |
CE2- |
9 |
SELATA- |
x |
x |
OE- |
43 |
i |
VS1- |
10 |
44 |
DIOR- |
x |
x |
IORD- |
11 |
CS1- |
x |
x(1) |
A9 |
45 |
DIOW- |
x |
x |
IOWR- |
12 |
i |
A8 |
46 |
13 |
47 |
14 |
48 |
15 |
i |
WE- |
49 |
16 |
INTRQ |
x |
x |
READY/ IREQ- |
50 |
17 |
Vcc |
x |
x |
Vcc |
51 |
Vcc |
x |
x |
Vcc |
18 |
52 |
19 |
53 |
20 |
54 |
21 |
55 |
M/S- |
x |
x(2) |
22 |
i |
A7 |
56 |
CSEL |
x |
x(2) |
23 |
i |
A6 |
57 |
i |
VS2- |
24 |
i |
A5 |
58 |
RESET- |
x |
x |
RESET |
25 |
i |
A4 |
59 |
IORDY |
o |
x(3) |
WAIT- |
26 |
i |
A3 |
60 |
DMARQ |
o |
x(3) |
INPACK- |
27 |
DA2 |
x |
x |
A2 |
61 |
DMACK- |
o |
o |
REG- |
28 |
DA1 |
x |
x |
A1 |
62 |
DASP- |
x |
x |
BVD2/ SPKR- |
29 |
DA0 |
x |
x |
A0 |
63 |
PDIAG- |
x |
x |
BVD1/ STSCHG |
30 |
DD0 |
x |
x |
D0 |
64 |
DD8 |
x |
x |
D8 |
31 |
DD1 |
x |
x |
D1 |
65 |
DD9 |
x |
x |
D9 |
32 |
DD2 |
x |
x |
D2 |
66 |
DD10 |
x |
x |
D10 |
33 |
x |
x |
WP/ IOIS16 |
67 |
CD2- |
x |
x |
CD2- |
34 |
Ground |
x |
x |
Ground |
68 |
Ground |
x |
x |
Ground |
Key: Dir = the direction of the signal between host and device. x in the Hst column = this signal shall be supported by the Host. x in the Dev column = this signal shall be supported by the device. i in the Dev column = this signal shall be ignored by the device while in 68-pin ATA mode. o = this signal is Optional. Nothing in Dev column = no connection should be made to that pin.
Notes: 1 The device shall support only one CS1- signal pin. 2 The device shall support either M/S- or CSEL but not both. 3 The device shall hold this signal negated if it does not support the function. |
This signal shall be grounded by the device. CD1- and CD2- are used by the host to detect the presence of the device.
Hosts shall provide CS1- on both the pins identified in table A.4.
Devices shall recognize only one of the two pins as CS1-.
This signal is optional for hosts and devices.
If this signal is supported by the host or the device, the function of DMARQ shall also be supported.
This signal is optional for hosts.
If this signal is supported by the host or the device, the function of DMACK- shall also be supported.
This signal is the inverted form of CSEL. Hosts shall support both M/S- and CSEL though devices need only support one or the other.
Hosts shall assert CSEL and M/S- prior to applying VCC to the connector.
This pin is used by the host to select which mode to use, PC Card-ATA mode or the 68-pin ATA mode. To select 68-pin ATA mode, the host shall assert SELATA- prior to applying power to the connector, and shall hold SELATA- asserted.
The device shall not re-sample SELATA- as a result of either a Hard or Soft Reset. The device shall ignore all interface signals for 19 ms after the host supplies Vcc within the device's voltage tolerance. If SELATA- is negated following this time, the device shall either configure itself for PC Card-ATA mode or not respond to further inputs from the host.
This Specification supports the removability of devices which use the ATA protocol. As removability is a new consideration for ATA devices, several issues need to be considered with regard to the insertion or removal of devices.
The following are recommendations to device implementors:
The following are recommendations to host implementors:
