Step 1, Solder Surface Mount ICs
Step 1, Component List
| Quantity | Color | Components |
| 1 | Red | STA013 MP3 Decoder IC, 32 pin SOP Package |
| 1 | Blue | CS4334 24 Bit Digital to Analog Converter IC |
| 1 | Green | MAX810-3.0, SOT-23 Package |
Step 1, Notes
These SOIC surface mount chips should be soldered before any
of the nearby through-hole components are added. The nearby
parts can obstruct your access to these tiny pins, making it
much more difficult to properly solder these parts.
Hi-Res Images Available
These eleven assembly diagrams are also available as high resolution
TIFF files that will look better when printed.
